Bayou Bert's RV9A Web Site
Date:  5-27-2014
Number of Hours:  10.00
Brief Description:  Test Fit Interior & FAB Bracket
You have to keep several steps ahead of where you are working present,
so you don't end up having to take things apart because you missed something.
I wanted to see what kind of area on the walls of the fuselage I will have after
the interior is installed. If I decided to run wire or tubes behind the interior was
there going to be a conflict.
Glad I decided to take the time. The interior side panels leave almost no room between
them and the fuselage skin. I will run everything down the center floor of the aircraft.
There is a tunnel there for the purpose.
I also completed a bracket on the front of the FAB. This is not called for in the plans
but recommended by those who's filter mount plates broke over time.
I made it out of 1/2" SS tubing so should last and now no wiggle in the air box.
FAB Bracket
FAB Bracket
